The Best UHD Burner to Burn 4K UHD Blu-rays
2019-03-19 04:33:00     Posted by Gabriel
14191
Summary: Though there are a few UHD burners in the market, you still can find a reliable one to use. DVDFab UHD Copy and UHD Creator would be the best UHD Blu-ray burner tools, which feature fast speed and high quality output.
Whenever it comes to burning a 4K UHD Blu-ray disc then we have limited reliable tools. And DVDFab 10 is one of those reliable UHD Burners. In this article we are listing two best UHD burners from DVDFab which are extremely good for copying and creating 4K UHD Blu-rays. Find these tools below.
Part 1: DVDFab UHD Copy: Best 4K UHD Blu-ray Burner and Copy Software
DVDFab UHD Copy is a fully functional 4K UHD Blu-ray copy solution and a UHD burner that is used to copy a 4K UHD Blu-ray disc to an 4K UHD Blu-ray ISO, folder, or to a blank Blu-ray disc (BD50 and BD25). Blank 4K UHD Blu-ray discs are expensive so you may not be buying them always to make a hard copy. The best option would be to save an exact copy of the 4K UHD Blu-ray disc as an ISO or a folder. You can save this ISO/folder on your computer’s hard drive. The good news is that you can always play this UHD ISO or folder from USB connected to a UHD players. So, this way you can save your money on blank 4K UHD Blu-ray discs. However DVDFab UHD Copy isn’t just limited to making ISOs and folders. You can also choose to burn blank BD50 and BD25 discs by going to ‘Advanced Settings’. DVDFab UHD Copy provides three main functions whose description is given below.
Main Functions of DVDFab UHD Copy
1. Full Disc:
The ‘Full Disc’ UHD Copy mode actually copies the entire UHD disc to an ISO, folder, or a blank BD25/50 Blu-ray discs. If you are creating an ISO or a folder then you can choose BD100 in ‘Adavnced Settings’. Selecting BD100 will make a 1:1 lossless copy of the entire 4K UHD Blu-ray disc. If you want a compressed copy then you can either select BD50 or BD25 and can save an ISO, folder or directly burn a blank BD25/50 disc. In any case the HDR10 and Dolby Vision quality will be retained. Select the Blu-ray drive from the save the ‘Save to’ location if you want to burn a compressed BD25/50 blank disc.
2. Main Movie:
A 4K UHD Blu-ray contains more than one movie file. So the ‘Main Movie’ UHD copy mode gives you the freedom of selecting the movie file of your choice instead of copying the entire 4K UHD Blu-ray disc. Copy a single movie file will be faster and save your time from getting invested in unnecessary copying process. Simply load the 4K UHD Blu-ray disc in the Blu-ray drive and open the 64-bit DVDFab10. Head to the ‘Copy’ mode and select ‘Main Movie’. Load the disc by clicking the +Add button, to select any of the main movie click ‘Choose Other Titles’.  You can also select the audio, chapters, and subtitles.
Only one main movie can be selected at a time. You can copy the main movie ans save it as an ISO (BD100, BD66, BD50, BD25 with 2160p quality), folder, or directly burn blank BD50/25 disc. In every case the HDR10 and Dolby Vision quality will be retained. If you are creating a BD100 ISO then the output file will be a 1:1 lossless copy. You can’t burn a BD100 physical disc due to compatibility issues among hardware UHD players, you can save a BD100 ISO instead. If you are burning a physical BD50/25 disc then the original 4K UHD Blu-ray data will be compressed to fit on these discs, however 2160p quality, HDR10, and Dolby Vision will be retained.
3. Clone/Burn:
If you just simply want to clone or burn your 4K UHD Blu-ray disc in a 1:1 lossless ratio then go with this option. The clone option can only clone a disc to an ISO file and it can’t burn a physical BD-XL disc as I told you earlier.
So, these were the three main functions provided by DVDFab UHD Copy. I hope you got the details correctly.
Part 2: DVDFab UHD Creator
If you are looking to create your own 4K UHD Blu-ray disc, ISO, or a folder then DVDFab UHD Creator is the UHD Blu-ray creator for you. With this UHD Blu-ray creator software you can convert almost any video to a 4K UHD Blu-ray format. And those movies or videos can be played on a 4K UHD Blu-ray player. So with this tool you can convert and burn your videos to blank BD50 and BD25 discs with the inbuilt DVDFab burning engine. And secondly you always have the option to save your videos as ISO (BD100, BD66, BD50, BD25). The disc and ISO output format can be selected from the ‘Advanced Settings’.
This UHD burner software is easy to use and converts any video to 4K UHD Blu-ray format. The time taken to process and create a UHD Blu-ray ISO or folder is quite large. So that’s DVDFab introduces Intel Quick Sync, and NVIDIA CUDA, and AMD Acceleration for faster processing. These technologies have been developed by their respective developers to enhance the processing speed of your computer hardware like Intel CPUs, Nvidia GPUS, and AMD CPU and GPU. To avail these hardware acceleration features you should have at least NVIDIA GeForce GTX 1050 or above.
With the advent of technology the 4K UHD Blu-ray is slowly becoming the standard of high definition entertainment. From TVs to smartphones, you can find 4K UHD Blu-ray all around. In this article we discussed two useful UHD burner and copy tools for burning, copying and creating 4K UHD Blu-ray discs and ISOs. The DVDFab UHD Copy software is really a nice UHD burner software for all your UHD burning and copying needs with options to create ISO, folder, or burn compressed Blu-ray media. And DVDFab UHD Creator helps you convert any video to a 4K UHD Blu-ray format. You can always try these two useful tools before making a purchase.
World's only UHD drive firmware flash tool to downgrade the firmware of a 4K UHD drive, so that the downgraded drive can be used to make backups for 4K Ultra HD Blu-ray discs.
You May Need Other Tools
DVDFab Blu-ray Copy
DVDFab Blu-ray Creator
Burn any videos to standard Blu-rays
DVDFab UHD Ripper
