Top 5 Best Blu-ray Players with Netflix Streaming Capabilities
2019-08-14 22:49:00     Posted by Amanda
2082
Summary: Would you like to watch incredible movies and shows by using Netflix on a smart TV? A compatible Blu-ray player with Netflix streaming capabilities will do it. Here are the best Blu-ray players across all price ranges we tested.
Netflix is a great platform to watch a lot of incredible movies and shows from your computer but did you know it works just as well on a smart TV? Well, it most certainly does and all you need in order to make it work is a compatible Blu-ray player with Netflix streaming capabilities. These types of players can be quite expensive but they tend to be a good investment in the long run. If you don’t mind losing out on a couple of features, however, there are also some very good options that are surpassingly cheap. With that in mind, today we’re going to take a look at some of the best Blu-ray players across all price ranges in the hopes that it can help you make an informed decision regarding which one you may want to invest in.
Part 1: Top 10 Best Blu-ray Players with Netflix Streaming Capabilities
Blu-ray Player with Netflix: Sony BDP-S6700
Sony’s BDP-S6700 is one of the cheapest Blu-ray players with Netflix functionality currently available on the market. The player is quite small in size and the overall design isn’t really anything to write home about, but it does look nice in an old school kind of way. The exterior may not look particularly impressive but it’s what’s on the inside that really counts here. For around $100 you can get a player that can handle standard 1080p Blu-ray content and is surprisingly good at upscaling it up to 4K. There’s also built-in Wi-Fi and Bluetooth along with a nice smart TV interface to look forward to, which lets you stream content from platforms like Netflix, Amazon Prime Video, YouTube, and more.
blu ray player with netflix
Blu-ray Player with Netflix: Panasonic DMP-UB700
If you’re looking for a Netflix Blu-ray player that can offer an amazing bang for your buck you may want to check out Panasonic’s DMP-UB700. The device retails for around $500 so it’s not exactly cheap, however, you do get what you pay for. The player can easily handle all types of Blu-ray formats and is particularly adept at 4K Blu-ray playback. In addition to incredible picture quality, the player also supports Hi-Res Audio playback so you’re getting the full AV package with this one. The only thing that drags this player down a couple of notches is the rather unimpressive build quality, which isn’t bad overall but it is somewhat lacking compared to other players in this price range.
netflix blu-ray player
Blu-ray Player with Netflix: LG BP330
The LG BP330 is one of the cheapest Blu-ray players with Netflix functionality you can buy right now. In spite of its low price tag, the player doesn’t actually feel cheap and is a lot more solid than you might expect. Just like our first entry, this device was also designed mainly with 1080p Blu-rays in mind but does a decent job at upscaling videos to higher resolutions. The player has built-in Wi-Fi and is capable of streaming content from not just Netflix but also Pandora, YouTube, and many other similar services. Not a whole lot of extra features to mention but the BP330 only costs around $73 so you’re already getting good value at this price point just based on the fact that it can play Blu-ray videos and supports Netflix streaming.
blu ray player which supports netflix streaming
Blu-ray Player with Netflix: Oppo BDP-103
Going back again to some of the more expensive options currently available, we have Oppo’s BDP-103 Netflix Blu-ray player priced at around $570. The device offers truly remarkable video and audio quality along with a few features that you may find very useful. Specifically, one of the highlights of the BDP-103 is the fact that it comes equipped with several different connectivity options, including Wi-Fi, two HDMI ports and 3 USB ports. This gives you a lot more control over what types of other devices you want to pair the Blu-ray player with, which is always a nice addition. If you’re interesting strictly in the Netflix streaming functionality, don’t worry because it fully supports it and the player can also stream from a wide range of other online services as well.
netflix blu-ray player which offers remarkable video and audio
Blu-ray Player with Netflix: Panasonic DMP-UB900
Last but not least we have another fairly expensive option in the form of Panasonic’s DMP-UB900, which sits at around the $550-600 mark. This model is more or less a direct successor to the UB700 we talked about earlier but features a few improvements that may make you consider spending the extra cash on it. The player was designed from the ground up with 4K UHD Blu-rays in mind and can handle them perfectly whilst offering flawless picture and audio quality. Not only can you stream regular Netflix content using this device but you can also enjoy 4K Netflix movies and shows if you happen to have a premium account to the service. The build quality also got a lot better since the UB700 but, strangely enough, the user interface seems to have taken a step back. Still, that’s only a minor gripe as the UB900 is otherwise one of the best Blu-ray players with Netflix streaming capabilities you can buy right now.
blu ray players with netflix streaming capabilities
Part 2: An Alternative Blu-ray Player to Play Netflix Blu-ray Movies
Don’t feel like investing in expensive Blu-ray player hardware at the moment? No problem because you can still watch Netflix content on any device using a multimedia player software like DVDFab Player 5. The Netflix app allows you to download certain movies to watch later if you’re running it on a compatible device such as an iPhone or a PC running Windows 10. This feature makes it very easy to store the movies and shows you want to watch locally and then play them later even when you’re offline. However, you’ll find it very difficult to run these files without the Netflix app. The best thing to do if you want to watch these movies offline is to record them using a screen capturing tool like Screencast-O-Matic or TinyTake and then you can easily play the resulting videos using DVDFab Player 5.
best netflix blu ray player
Player 5 is a premium media player that supports all the most popular formats, including 3D, 4K, 4K UHD, and many more. The player also features navigation menu support for all types of DVDs, Blu-rays and 4K UHD Blu-ray discs along with two different playback modes designed for PC and TV, respectively. That, combined with advanced features like 3D upscaling, HDR10 and HI-Res audio support, customizable playlists and more, make it an excellent alternative to Netflix Blu-ray player hardware. Not to mention, it’s a lot cheaper. The most expensive Ultra version of the software is only $99 (it will be even cheaper if there is promotion) and offers similar capabilities to the $500+ Blu-ray hardware we talked about earlier. In addition, there’s also a Standard version priced at only $59 and even a free version if you want to first check it out and see if you like what it has to offer.
A Blu-ray player with Netflix streaming capabilities is a must if you’re the type of person that enjoys high-quality content displayed on a large-screen TV. However, that doesn’t necessarily mean you have to spend hundreds on expensive hardware. A good piece of software like DVDFab Player 5 can get the job done just as well and you can also use it on both your TV and your computer, which means double the value.
From this article, you have known 5 best hardware Blu-ray players with Netflix streaming capabilities and a software Blu-ray player with Netflix. As a Netflix lover, maybe you usually rent DVDs or Blu-rays from Netflix. Then do you usually come across the Cinavia error? How to fix Cinavia on Netflix DVD or Blu-ray? See this article to find answers.
You May Need Other Tools
DVDFab Blu-ray Copy
DVDFab Blu-ray Ripper
DVDFab Blu-ray Creator
Burn any videos to standard Blu-rays
  • Discount
    Copy & Paste Coupon Code:
    AUFM-FAB-OFF
    When Checking out.
    Aug 26, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
    The Universal Master Key to
    Access Protected DVDs & Blu-rays
    Price: $69 Buy Now
    World's Best DVD Combo to
    Tackle All DVD Copying/
    Burning/Cloning/Ripping Issues
    Price: $84.9 Buy Now
