Reviews on Top 8 Best Blu-ray Burning Software
2019-04-25 05:25:29     Posted by Ada
15689
Summary: There are so many free and paid Blu-ray burning software programs in the market, which one is the best one? Here we have made a list of top 8 best Blu-ray burning programs for Windows and Mac for you to make a choice.
Though cloud storage and USB stick are prevalent these days, disc, especially Blu-ray disc, is still an excellent way for storing and sharing large data and high definition video/movie. There are so many free and paid Blu-ray burning software programs in the market for you to back up and create Blu-rays, so you may feel dizzy if you have to pick out a good Blu-ray burner to use. Don’t worry, we have tested and found top 8 best Blu-ray burning programs for Windows and Mac for you to burn Blu-ray easily and quickly. Now let’s have a look to these best Blu-ray burners.
1. DVDFab Blu-ray Copy
2. DVDFab Blu-ray Creator
3. Express Burn
4. ImgBurn
5. Leawo Blu-ray Creator
6. BurnAware
7. Ashampoo Burning Studio
8. CDBurnerXP
DVDFab Blu-ray Copy is a powerful Blu-ray burning program that can copy and burn data/bootable Blu-ray and standard Blu-ray movie, including 3D Blu-ray movie, to blank Blu-ray discs. It provides 5 burning modes, namely Full Disc, Main Movie, Customize, Merge and Clone/Burn, which can fulfill your various burning needs. With Clone/Burn mode, you can burn data and bootable Blu-ray disc, and with Customize mode, you can customize your Blu-ray movie as the way you like, which means you are able to choose the titles, chapters, audio tracks and subtitles you want, and customize your own menu. The preview feature allows you to preview the titles before you choose a title. This Blu-ray burner also contains the feature of compressing BD50 to BD25.
As we all know, commercial Blu-ray titles contain many protections that stops you from burning and copying the movie for personal use. DVDFab Blu-ray Copy comes with a built-in decrypter which can circumvent nearly all Blu-ray protections and remove all region codes. But what should be noted is that DVDFab is only for legally personal use.
In fact, DVDFab Blu-ray Copy not only works on Blu-ray discs, but also can deal with Blu-ray folder/ISO files. It is powerful enough to burn any Blu-ray disc/folder/ISO file to Blu-ray disc/folder/ISO file. Moreover, it also can burn Blu-ray to DVD/AVCHD disc.
Though so many advanced features are included, DVDFab Blu-ray Copy is easy to use. If you want to use the basic burning feature, you only need to insert the Blu-ray source or drag & drop the Blu-ray folder/ISO file to the main interface, choose the burning mode and click the “Start” button. The Blu-ray burning software is a good choice both for novice and veteran users.
Due to its support to the newest hardware acceleration technology, DVDFab Blu-ray surpasses many competitors in burning Blu-ray at flash speed.
DVDFab Blu-ray Copy is available for both Windows and Mac systems.
DVDFab Blu-ray Creator is another Blu-ray burning software that is used for burning various videos to blank Blu-ray disc/folder/ISO file. All kinds of video including videos downloaded from YouTube and recorded with camcorder are supported. DVDFab Blu-ray Creator is a flexible Blu-ray burner that allows you to burn and merge more than one video into one Blu-ray disc and gives you the right to arrange the playback order. This Blu-ray burning program is also a versatile one, which enables you to customize your own Blu-ray playback menu with the built-in menu templates. You are able to set the frame, font, layout, etc. in the menu template.
All DVDFab programs are pretty easy to use, and so is DVDFab Blu-ray Creator. To start the burning process, you only need to load the video/videos you want to burn, choose the Blu-ray creator mode and click the “Start” button.
Of course, DVDFab Blu-ray Creator also contains some advanced features for you to customize your own Blu-ray disc. You are able to choose the audio tracks and subtitles you want, or to add external subtitles. When adding an external subtitle track, a preview window will pop out for you to synchronize the subtitles with the video. At the bottom of the main interface, you can choose how many copies you want to burn. At the “Save to” part, you can choose to burn the video to blank disc, or Blu-ray folder/ISO file that can be stored on hard drives.
DVDFab Blu-ray Creator is a fast Blu-ray burning program which can burn video to Blu-ray with only a few minutes on Windows and Mac. Though fast in burning speed, it still can output Blu-ray with great video quality.
3. Express Burn
Express Burn is another quick and easy-to-use disc burning software program. It can burn AVI, MPG, VOB and all DirectShow supported video formats to Blu-ray discs. Its advanced feature lies in that it allows you to create and manage chapters on Blu-ray disc. It is not as versatile as DVDFab in burning Blu-ray, but it contains the features of Audio CD recording, Video DVD authoring and Data CD/DVD/Blu-ray writing. So it’s ok to choose Express Burn if you still want to burn CD and DVD other than enjoying the basic Blu-ray burning feature. Express Burn only supports Windows system. The burner has a free version, but the free version can only be used to burn normal CDs.
4. ImgBurn
ImgBurn is a 100% free and light weight CD/DVD/HD DVD/Blu-ray burning application. It can burn various files and image files to Blu-ray discs at ease. ImgBurn also can create playable Blu-ray discs from BDAV/BDMV folder, and that’s what makes it stand out from a lot of free Blu-ray burners. As a matter of fact, ImgBurn is a Blu-ray burner with many other advanced options. In addition to Blu-ray, it also can burn CD/DVD/HD DVD and create playable DVD. It also has the ability to create image file from files on computer or network and read a disc to an image file. ImgBurn is a powerful disc burning software but it only works on Windows system.
Leawo Blu-ray Creator is a relatively comprehensive Blu-ray burning software program that can burn and convert videos in various formats to playable Blu-ray and ISO image file. There are many menu templates in Leawo Blu-ray Creator, and you can DIY your menu according to your preferences. There is also an option for you to burn common 2D video to 3D Blu-ray. The built-in video editor allows you to trim, crop or add watermark to your video. The Blu-ray burning software is available for both Windows and Mac systems.
6. BurnAware
BurnAware is a full-fledged Blu-ray burning program with a clean and beautiful interface. The interface of BurnAware is straightforward and intuitive, and all its functions and features are clearly classified into four sections, namely Data, Multimedia, Disc Images, and Utilities. You can easily find the tool you want to use. With BurnAware, you can create and burn standard/bootable Data Blu-rays and make BDMV discs that can be played on a Blu-ray player. Its copy feature is also a highlighted part which enables you to copy disc to ISO image and copy Blu-ray disc to disc. CD and DVD are supported by this Windows disc burner.
Ashampoo is a handy Windows Blu-ray burning program. It can create Data Blu-ray discs and Blu-ray discs with autostart capability. It also has the ability to create Video Blu-ray from prepared folder and get disc images from Blu-ray Blu-ray discs. It includes an advanced function for you to create modified copies of Blu-ray discs. Ashampoo Burning Studio provides a step-by-step instruction when you make a Blu-ray burning, but it lacks some customization options for you to customize your Blu-ray. It also can be used to burn CD and DVD.
8. CDBurnerXP
Don’t be fooled by the CD in its name, CDBurnerXP in fact is a free and helpful disc burning program. All kinds of CDs/DVDs/Blu-rays are supported by this burning tool. With CDBurnerXP, you can burn any data to Blu-ray discs and make a copy of a Data Blu-ray. The burning software also allows you to burn ISO files to discs, create ISO images from discs. The major functions of this Windows burner are all presented in its main interface, so novice users can find the right tool easily, or they can go to its official website to find the detailed burning steps.
Now the features and functions of top 8 best Blu-ray burners have been listed above, so do you have any idea to choose which of them? If you are still undecided, my advice is to try each or several of them yourself. DVDFab Blu-ray Copy and Blu-ray Creator should be on the top of your try list, because they are powerful enough and provide a 30-day free trial. So move now!
Blu-ray burning software allows you to burn videos/Blu-rays to Blu-ray discs, but if you want to rip Blu-rays to digital video formats, you may check out how to rip Blu-rays to MP4/MKV/AVI/MP3.
You May Need Other Tools
DVDFab Blu-ray Cinavia Removal
Remove Cinavia from the audio track of Blu-ray
DVDFab DVD Copy
Copy any DVD to DVD disc/folder/ISO file
DVDFab DVD Creator
Burn any videos to standard DVD
  • Discount
    Copy & Paste Coupon Code:
    JYPM-FAB-OFF
    When Checking out.
    Jul 22, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
