Top 3 Blu-ray Copy Software Programs
2019-03-19 06:49:29     Posted by Amanda
10155
Summary: Sometimes you may need to copy or burn your Blu-ray movies for backup. To copy Blu-ray you have to turn to a Blu-ray copy tool. Here we have found 3 best Blu-ray copy software programs to help you make Blu-ray copies easily.
Don’t we all prefer watching Blu-ray movies and videos over and over again? But what if your DVD and the Blu-ray movies get affected by scratches, fingerprints, loss, damage etc.? What if you no longer have the DVD? In such cases, it is better if you have a backup of the Blu-ray movie or video. You can either back it up by copying it onto a blank DVD or you can also create a copy on your computer, which would be much more convenient. This is where Blu-ray copying software come into the picture. These software help you create a copy of the original Blu-ray file which can be played in any popular Blu-ray player. You can also save this in your PC’s hard drive.
However, due to the huge number of Blu-ray copying software available online, it becomes difficult to choose the best one. In this article, you can choose from the list given below, an ideal Blu-ray copy software program that would meet all your requirements and desires.
DVDFab Blu-ray Copy
DVDFab Blu-ray copy software is known to be the first fully-featured Blu-ray copier, that is strong enough to copy any kind of Blu-ray video or movie to any kind of Blu-ray output (DVD/AVCHD disc). An important characteristic of Blu-ray 3D is that it completely supports Blu-ray 3D. Using this software, you can copy any BD 50 3D to BD 25 3D in the very original format. You can also copy 3D Blu-ray to 2D Blu-ray or Blu-ray SBS 3D. You will also be able to customize the copied version of any movie title in 2D or 3D Blu-ray that you choose. It covers both the basic requirements and the advanced requirements. It can burn any Blu-ray movie to a blank DVD disc. Another important feature of this software is that it can burn Blu-ray to various blank DVD discs such as DVD +R/RW, DVD-R/RW, DVD+R DL and DVD-R DL in order to cut down on the price. It also comes handy if there is no Blu-ray disc available readily or when you require a high cost-performance DVD backup.
It’s quite intuitive and the interface is user-friendly. The process is neatly laid down, step by step. Moreover, it supports a wide range of languages too. The speed of copying is excellent, and it’s ensured that there is no loss in the output quality.
Leawo Blu-ray Copy
Using this software, Blu-ray can be backed up to ISO image or folder in order to save on your computer hard drive. It makes way for you to back up your Blu-ray content to blank BD50 or BD25 disc or your hard drive in the form of ISO image or folder. It has another amazing feature that is, it could successfully copy all Blu-ray discs in the market including the most recent releases. Discs originating from various places can also be backed up. Moreover, it also has the capacity to copy 3D Blu-ray movies without having to let go off the 3D effect. The resultant audio quality and image quality are kept as far as possible, similar to the original quality. You can bring about 1:1 disc duplication without compromise on the quality. There are also many more customization options like subtitle and audio track options etc.
Blue-Cloner
Blue-Cloner was created by a company known as Open Cloner, specializing in digital media distribution. It is mastered at making a perfect 1:1 Blu-ray copy, a complete movie copy, movie-only copy, split and customized copy. It is also capable of copying Blu-ray movie to DVD and AVCHD disc. It is good at removing region codes, hence letting you play the copied Blu-ray version in any region. The company introduces constant updates and as a result, Blue-Cloner 5 can copy any Blu-ray movie in the market. The copy speed is also enhanced up to a large extent.
The above software programs are hence easy solutions for a scratched or lost Blu-ray DVD disc. Always have a backup!
You May Need Other Tools
DVDFab DVD Copy
Copy any DVD to DVD disc/folder/ISO file
DVDFab Blu-ray Creator
Burn any videos to standard Blu-ray
DVDFab DVD to Blu-ray Converter
Convert DVD to Blu-ray disc/folder/ISO file
  • Discount
    Copy & Paste Coupon Code:
    JYPM-FAB-OFF
    When Checking out.
    Jul 22, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
