DVDFab Free Download
Download
Anaglyph 3D, SBS 3D and Top/Bottom 3D
2017-08-04 02:32:23
DVDFab has a super powerful 3D converter software bundle which includes DVD Ripper, Blu-ray Ripper, Video Converter and 2D to 3D Converter. With those tools working together, you can turn regular DVDs, Blu-rays and videos into 3D videos in a couple of formats, like side-by-side 3D, anaglyph 3D, two separate files, and even two video streams in one file. The converted 3D videos play quite smoothly 3D armed computers, 3D TVs, glasses-free 3D smartphones, or other compatible 3D devices.
Here this tip is to teach you how to convert your regular DVDs, Blu-rays and videos into 3D videos.
Turn 2D Videos into 3D Videos> Step 1: Download and install the latest DVDFab 9 onto your computer;
Turn 2D Videos into 3D Videos > Step 2: Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the to-be-converted 2D DVDs from your disc drive;
Sidenote: Partnered with 2D to 3D Converter, Ripper tools will convert 2D DVDs and Blu-rays into 3D videos; To convert 2D videos into 3D videos, you need select Converter tool at this step.
Turn 2D Videos into 3D Videos > Step 3: Click the Profile Box (or Profile Icon) which takes you to DVDFab Built-in Profile Library, and then select one profile from the “3D Format” column,for example, “3d.mkv.h264.ac3” from MKV section;
Turn 2D Videos into 3D Videos > Step 4: Click “Advanced Settings” button behind the Profile Box to do corresponding settings regarding to video, audio, subtitle and 3D Format;
Sidenote: click 3D tab, you can choose one 3D format from the available options, side-by-side 3D, anaglyph 3D, two separate files, and even two video streams in one file.
Turn 2D Videos into 3D Videos > Step 5: Click the “Edit” button at the top left corner of Operation Window if you want to customize the resulting 3D video. After you have done here, return to the main interface to “Start” the converting process.
Product you need order: DVD Ripper, Blu-ray Ripper, or Video Converter and 2D to 3D Converter
For more info, please go to: www.dvdfab.cn/2d-to-3d-converter.htm
  • Discount
    Copy & Paste Coupon Code:
    JYAF-FAB-OFF
    When Checking out.
    Jul 29, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
