How to Rip and Convert DVD to FLV with DVD to FLV Ripper?
2017-08-03 22:32:23
FLV is a common format. Videos in FLV format almost can be played by all playback devices and softwares. If you want to watch your DVD movie on your computer or portable devices, you can convert DVD to FLV with ripper tool. DVDFab DVD Ripper is a good choice for you for it can help you convert DVD quickly with minimal quality loss.
How to Rip and Convert DVD to FLV with DVD to FLV Ripper: Step 1 > Run DVDFab 10 and choose the Ripper module.
How to Rip and Convert DVD to FLV with DVD to FLV Ripper: Step 2 > Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to FLV with DVD to FLV Ripper: Step 3 > Navigate to the profile library on the top left corner of the main interface and choose Format > Video > FLV.
How to Rip and Convert DVD to FLV with DVD to FLV Ripper: Step 4 > Now you can choose the titles, chapters, audio tracks and subtitles, define the names of the titles, and do advanced settings according to your needs. You even can edit the DVD video with the built-in editor.
How to Rip and Convert DVD to FLV with DVD to FLV Ripper: Step 5 > Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
If you want to get more information about DVDFab DVD Ripper, please go to https://www.dvdfab.cn/dvd-ripper.htm.
