DVDFab Free Download
Download
How to Copy DVD to Computer / PC / Hard Drive?
2018-11-29 10:49:25
If you do not have a blank DVD disc, you can copy your DVD to your computer or hard drive for backup. But how? DVDFab DVD Copy can help you copy your DVDs effortlessly and save them as DVD folders or ISO files to store on your PC or hard drive. Now let me show you how to copy DVD to computer or hard drive with DVDFab DVD Copy.
Step 1: Choose a copy mode
Run DVDFab 11, choose “Copy” module and click the mode switcher on the top left corner of the main interface to choose a copy mode. You have 6 modes (see Note at the end) to choose. Here I take Main Movie mode as an example.
dvd copy
Step 2: Load the source
Insert a DVD disc and DVDFab will load it automatically, or you can click the “Add” button to load the source manually.
copy dvd
Step 3: Personalize your DVD
After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and make advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
dvd converter
copy to dvd
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select a directory by clicking the "folder" icon is to save the output as a DVD folder on your hard drive or PC; to select a directory by clicking the "image" icon is to save the output as an ISO image file on your hard drive or PC.
Note:
6 modes:
For more detailed information, please visit DVDFab DVD Copy.
  • Discount
    Copy & Paste Coupon Code:
    JYPM-FAB-OFF
    When Checking out.
    Jul 22, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
