How to Rip DVD with DVDFab DVD Copy?
2019-09-06 03:54:42
Sometimes, you may want to rip your favorite DVD movies or shows onto your computer or hard drive for backup and safe storage. DVDFab DVD Copy can help you rip your DVDs fast and easy. The guide will answer the question how to rip DVD with DVDFab DVD Copy. Dive in below to find out.
Step 1: Choose a mode
Run DVDFab 11, choose “Copy” module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes to choose. Here I take Main Movie mode as an example.
dvd copy
Step 2: Load the source
Insert a DVD disc and DVDFab will load it automatically, or you can click the “Add” button to load the source manually.
 copy a dvd
Step 3: Customize your file
After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and make advanced settings if needed. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
how to rip a dvd
how to rip a dvd
Step 4: Select a dictionary
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select a directory by clicking the "folder" icon is to save the output as a DVD folder on your hard drive; to select a directory by clicking the "image" icon is to save the output as an ISO image file on your hard drive.
dvd copy
Note:
You are not allowed to do any operation to customize your output DVD on Clone/Burn mode; on Full Disc mode, you cannot choose the titles, chapters, audio tracks and subtitles but you can make advanced settings.
For more detailed information, please visit DVDFab DVD Copy.
