Rip 3D Blu-ray to 3D M2TS
2017-11-23 04:31:44
M2TS format is a high quality container format which can give videophiles astounding audiovisual experiences. If you want to rip 3D Blu-ray but save the high quality, you can rip 3D Blu-ray to 3D M2TS video. DVDFab Blu-ray Ripper is the best 3D Blu-ray to 3D M2TS converter that can convert 3D Blu-ray to 3D M2TS easily and quickly. The following is the detailed steps of ripping 3D Blu-ray to 3D M2TS with DVDFab Blu-ray Ripper.
Step 1: Load the source
Step 2: Choose the 3D M2TS profile
Navigate to the profile library on the top left corner of the main interface, choose Format > Video > Filter, check the 3D option and choose the 3D M2TS format.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, and define the names of the chosen titles. Click the “Advanced Settings” icon, you can set the parameters of video/audio and choose the 3D type. Click the “Editor” icon, you can edit the video with the built-in editor.
Navigate to the bottom of the main interface and click the "folder" icon to select a directory to save the output video.
Click the “Start” button to start the process of ripping Blu-ray 3D to 3D M2TS video.
This tip shows you how to rip and convert Blu-ray, but if you want to convert video, you can try DVDFab Video Converter, a versatile video converter that can convert video to formats like M2TS, AVI, FLV, MKV, WMV and more.
  • Discount
    Copy & Paste Coupon Code:
    SEPM-FAB-OFF
    When Checking out.
    Sep 23, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
  • DVDFab DVD Copy
    Fast
    Easy
    High Quality
    Free Download
