NEW
4K UHD Player
DVDFab Free Download
Get 30-Day Free Trial
Windows 10/8.1/8/7
macOS 10.10 - 10.14
Ubuntu 16.04 and above
2019-03-19 04:05:10 Posted by Amanda
Summary: Do you want to convert MP4 videos to MP3 and enjoy them on your audio player? You can read the article to find out the top 10 best MP4 to MP3 converters.
If you’re among the music fans, you must be eager to know how to convert MP4 to MP3 files with ease. MP3 format can do miracles when it comes to reducing a lot of space and provide that extra needed space to save additional music. Converting MP4 format files to MP3 is just not any easy task, since various applications are available on the website for the same. So ease your task of converting, we have got the best 10 MP4 to MP3 converters for you in the below article.
DVDFab Video Converter is the best and the easiest software used to convert any format video to another trendy video format. It helps to in convert MP4 format file to MP3 format along with other audio formats with no trouble and proficiently. Besides all this, you even get a trial of 30 days [need not to mention that it is a free trial]. In this free trial, you have no limits to convert numerous videos as per your requirement. Cherry on the cake, you just don’t have to spend a single penny. DVDFab Video Converter is video converter software that converts video of any format to your required format promptly and with ease. It is one of the superlative MP4 to MP3 converter tools of all.
Apart from converting your MP4 video to MP3 format, the wonderful tool even gives highest quality output videos as well as provides high speed conversion. We bet you not only save your time with this tool but also get satisfaction of the work done precisely. More to the list is you get amazing features such as tailoring and customizing the settings, editing numerous videos, getting high-speed conversion as well as using batch conversion feature. Undeniably, DVDFab Video Converter is one of the best tools amid the entire bunch of tools available. You won’t regret using this software as a MP4 to MP3 converter.
Owing to its unlimited and great quality features, one will definitely like Format Factory as aMP4 to MP3 converter. In case you come with a big size file, the tool will do the necessary size reduction but that too without hampering the quality of the file. As the software supports 62 different languages, it is hard to find someone having a language issue while using the tool; also simply can select from the wide of language options in which you are comfortable with. Other features include ripping DVD, repairing damaged files, and common conversion process on various platforms as well as file formats. As a MP4 to MP3 converter, you can enjoy a free trial of the tool before going for any formal purchase. The cost of the tool is worth paying as it provides various features while converting MP4 to MP3. However, the software does not have support for multiple files simultaneously and that it is available for Windows only.
Any Video Converter is the one people opt for due to its wonderful features among which is conversion of MP4 format file to MP3 format file without spending any penny. The software is a fully featured tool that helps enhance the experience when you use the tool specifically for as a MP4 to MP3 converter of HD videos since it is very easy to use. You can even know the quality of the video, make animated GIFs merely from a video along with create HTML5 video using an embedding code. The free trial is easily downloadable for converting MP4 to MP3. The software provides super high speed MP4 to MP3 conversion and also guarantees the supreme quality of the MP3 converted output file. It further allows the batch conversion of various different files in one go. The tool is available for both Mac and Windows. On the other hand, the tool takes a bit long for loading the videos.
iDealshare VideoGo is free MP4 to MP3 convertor tool working at great speeds. It can further work for both audio and video files. One can use this software as an online MP4 to MP3 converter too instead of downloading the tool. And this becomes the extra benefit provided by the tool. Editing process is just a few steps far. The converted MP3 files will playback with no trouble on any platform and device. 100% quality of the MP4 to MP3 converted files is provided. It is very easy-to-use software and also provides a faster speed for conversion. The tool is available in both the versions—Mac and Windows. However, the software requires some bugs that are to be fixed particularly on other file format conversion and support.
Being a 4-in-one tool, with Faasoft Video Converter one can convert MP4 to MP3 along with other features such as edit, download, and play files with ease. In mere a single click, one can download the MP4 to MP3 converter tool for its free trial. The software has a very high rate of compatibility. You can enjoy over 160 files in HD, SD as well as 3D. There is no loss of quality after the file is converted from MP4 to MP3 as well as you get the speeds that are 30 times faster as compared to a normal editor. Various editing tools offered by the software are crop, rotate, split by chapter as and adding effect, trim, watermark along with subtitle. Owing to its user-friendly interface and features, it is one of the powerful tools.
Zamzar is one of the online tools that can be utilized as a MP4 to MP3 converter tool. The software was introduced back in 2006. In addition, it can convert document as well as images too. The software has a simple and direct way to convert videos to MP3 from MP4 without the need of installing the software on your PC via the computer browser. The software can be used to convert a huge array of files. However, Internet is mandatory to convert any file with this software. So if you do not have Internet, no conversion. Furthermore, the tool just cannot be used to convert a file bigger larger than 100MB size. Also, for converting any file, one first needs to upload the file from the PC to the site, and then convert it. More to the disappointing list, the speed of conversion is also slow.
FFmpeg tool is even more than a MP4 to MP3 converter. It can not only convert MP4 format file to MP3 converter, but it can also record as well as stream audio and video files. The tool is accessible on Windows, Mac as well as Linux operating systems. So you can use this MP4 to MP3 converter on any platform. Furthermore, the software makes sure of easy video files conversion from MP4 to MP3 format. It can also convert huge files with ease. Moreover, the tool provides support to numerous formats. However, the software is just not that easy and user-friendly as compare to others. CPU is used excessively while converting big files.
Being a free and open-source MP4 to MP3 converter, Handbrake attracts people with its powerful features and ease-of-use for video transcoding. All this allows one to easily convert MP4 to MP3 as well as rip any DVDs (non-copy protected) along with convert various videos formats to very well-known formats, that is, MKV and MP4. The software has a presets system that allows new users to perform the conversion of MP4 to MP3 files along with ripping of DVD videos quickly. The advanced users can enjoy surplus features as well as settings that help edit the output as per their requirements such as select from a wide variety of video and audio codecs, chapter and subtitle support. It also has a bloatware-free installer.
DVDVideoSoft Free Studio is a one of the best MP4 to MP3 converters owing to its various media features. The tool not only converts your MP4 file to MP3, but also provides media ripping, video downloads, and much more. As far as MP4 to MP3 conversions are considered, various device presets along with quality profiles are available. Genuine output configuration in these presets is fairly light, with converters and presets awkwardly distributed across various submenus. Yet, it has various additional features apart from conversion. However, DVDVideoSoft will advise to install additional software. So take care and read all the checkboxes while installing the software.
Instead of using and providing loads of technical options and settings to its users while converting MP4 to MP3, Convertilla uses a very simple methodology, which allows for easy conversion of MP4 to MP3 files as well as to a number of other formats. Its presets are compatible with a wide range of mobile devices. Options for customization of output are not too much, with options for quality along with an output resolution dropdown. The tool’s simplicity is the thing that outstands Convertilla as an easy-to-use, simple converter.
In the above article, the top 10 different yet best MP4 to MP3 converters are discussed. All the above-mentioned tools can help you know how to change MP4 to MP3 format files. We hope that the above article has helped you out and solved your dilemma of converting any MP4 format file to MP3 format file. One of the MP4 to MP3 converters must have helped you complete your task.
By the way, we find 2 ways to convert instagram video to MP4. If you are interested, you can go for a look.
The top-notch video downloader software to download online videos from YouTube, Facebook, Vimeo, Twitter, Instagram, and 1000+ other popular audio & video sharing websites.
Video editing might sound like something that only professionals do but there are basic free video editing software that makes it possible for individuals to make video edits. Now let’s check the top 20 free video editing software.
Here is the list of top 10 best free video converter programs and free online video converters for you to convert videos to MP4, AVI, MOV, MP3, AAC, FLAC and more freely.
YouTube has become the new search engine for videos, music videos or everything. If you’re blank what you want to watch or listen on YouTube, please check the top 10 best music videos of all time.
Hot Sellers
